Scaling direction parameter in PML node
Posted 19 janv. 2011, 11:14 UTC−5 RF & Microwave Engineering Version 4.1, Version 4.2 5 Replies
Hello everyone,
I have a problem with PML. I don't fully understand one parameter and that's Scaling direction. It is located in the Manual scaling sub-node which is located in the PML node if the type of PML is set to General. In the RF module manual is written "The first parameter" (Scaling direction) "sets the direction from the interface to the outer boundary." From this
sentence I would understand this parameter can take the value of 0,1 or -1. But I know from Comsol this parameter can take any real number. And here is my misunderstanding. Which direction does this parameter scale? Is it the real direction or the imaginary direction or both of them? I eliminate the last possibility by myself because both directions should be scaled by the PML scaling factor from the PML node if I correctly understand the equation (2-1) from the RF module manual, page 29.
Jaroslav Luksch
Jaroslav Luksch
5 Replies Last Post 6 sept. 2011, 02:17 UTC−4
