phase change
Posted 20 sept. 2016, 22:52 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 5.0 0 Replies
my problem is cooling and dehumidification fan coil the flow inside tube water and outside is moist air with relative humidty so which physics should be selected to solve the mass transfer and condensation of the water vapor in the air as water inlet below the dew point of the air
thanks
Hello Mohamed Shawky Zaid
