9 years ago
31 août 2016, 03:26 UTC−4
in Comsol this topic is treated different than in other FEM codes.
1. In the meshing step you create a tetrahedral mesh.
2. In the discretisation setting of the physics section you select Lagrange and quadratic.
Then this will be like a 10-node tetra in Ansys.
The discretisation is not visible by default and you must activate it in the model tree ("Show" button).
Also the quadratic Lagrange is default for many types of physics.
Regards
Jens
Regards
Jens
9 years ago
31 août 2016, 04:02 UTC−4
Regards
Jens
Thank you for your reply.. But what if i want to export the displacements DX DY DZ on the 10 nodes and the connectivity file to use them in other calculation... the connectivity file will include all the faces with just 3 or 4 faces ... i need a connectivity file for the 10 nodes + the displacements on these nodes... is it possible ?
thanks
[QUOTE]
Regards
Jens
[/QUOTE]
thanks
9 years ago
5 sept. 2016, 04:23 UTC−4
Have you tried the Data Export in the Results section? Under "Advanced"
there is a combe box labeled "Evaluate in" where you can select "Lagrange Points"
Regards
Jens
Regards
Jens
Lars Gregersen
COMSOL Employee
9 years ago
5 sept. 2016, 04:30 UTC−4
If you have access to LiveLink for Matlab you can use mpheval to extract data for each node (use refine=2 for second order lagrange elements).
Using mphmeshstats and mphxmeshinfo you can get all the information you need about mesh data and elements including numbering and connectivity.
Lars Gregersen
Comsol Denmark
Lars Gregersen
Comsol Denmark
