Bike cab simulation - Relative error greater than relative tolerance
Posted 3 août 2016, 16:30 UTC−4 10 Replies
I´m trying to model a bike cab for my graduation project from university. I stated with a simple model based on the truss bridge tutorial so I can easily modify the tube sections and get fast solutions to test them.
However, I get the
"Failed to find a solution.
The relative error (2.4e+002) is greater than the relative tolerance.
Returned solution is not converged."
error.
I have tried modifying the mesh and checking boundary conditions but can't get it to find a solution.
I did model the cab later as a solid and got a nice solution with the same boundary conditions, so I'm not sure where the error comes from, maybe it's something simple that I'm over looking.
I tried to attach my file but the attach button doesn't seem to be working, let me know and maybe I can email it if someone can hae a look at it.
Thanks for any help!
Although the tutorial is called Truss Bridge, it actually uses the beam interface along with shells (which I will also use farther down the road in a more complex model with some metal plates that are used to reinforce the structure).
Not sure if that's what you meant.
Thanks.
Try attaching your model again after clearing the solution to reduce file size if needed.
No problem.
Tried uploading my file in different computers and at home but the "Attach File" button doesn't seem to work, it doesn't open any new window or any place to select the file, not sure why.
Anyway, I'm relatively new to COMSOL so, about the boundary conditions:
1) I added fixed constraints on 5 different points along the rear axle of the cab, I believe this should remove motion on all axes and also block rotation around the 'x' and 'y' axes (the rear axle runs along the 'z' axis)
2) Added prescribed displacement at the end of the front tube (known as headtube), it is set to zero on 'y' and 'z', allowing the endpoint to move only along 'x', besides being part of the load case, this should block rotation around 'z' axis.
3) Added loads at the top of the headtube, pedal axel and driver and passenger seats.
Let me know if you see anything is missing please, I will continue to investigate why I can't attach a file, maybe it's because this is my first post? Don't know.
Thanks again Jeff and anyone else who can help!
The "Attach" button seems to be misbehaving today on Firefox, but works on IE and Chrome. If you tried on Firefox earlier, can you try using one of those browsers to upload your file?
Sorry about this, I have reported the problem to our web team.
I was in fact using Firefox and it works in Chrome.
So, I attach the file, you'll see it's a pretty simple case I believe.
Again, thanks and any help is appreciated,
Alfredo
Note that if you fix point 6 (where the problem seems to be, see above) the solution converges nicely.
Jeff.
I will continue to add complexity to the model and come back if I find any obstacles hehe
Thank you very much for your help Jeff and have a great day,
Alfredo
Could you take a look at this model where I try to incorporate the shell interfece? I'm not sure if I'm missing some border condition to make it converge or if I'm using the beam connections as I should.
Also, suppose that some of the edges that represents the shells (edge 28, the long one along the z axis and edges 98, 104, 113, 114 and 119 and similar) is not supposed to be a beam, so I'm not sure what data to enter there, it should not be in the beam interfece but I know I should imput some properties on it, right? I can't delete them either as they define the region that represents the shells.
But even if I imput them as beams (the one that says "with all edges as beams"), the model will still not converge, so not sure what's happening.
Besides the Truss Bridge tutorial, are there any other examples that ilustrate the combination of beams and shelss?
Tailwinds,
Alfredo
Suggested Content
- FORUM How to see the relative permittivity of a material
- BLOG Intro to Modeling Transient Heating of Solids in COMSOL Multiphysics®
- KNOWLEDGE BASE Improving Convergence of Transient Models
- BLOG How Do Bicycle Pedals Stay On?
- FORUM The relative error (0.027) is greater than the relative tolerance in Optimization Module
