BC contains dependent variable evaluated at boundary
Hi All,
I am trying to solve a 1-D steady state differential equation. One of the boundary condition (BC) is such that I am trying to evaluate the dependent variable at the boundary.
BC: Flux @ boundary 1 = f(dependent variable) @ boundary 1
I read in another discussion that using projection operators may do the trick.
However I tried using linear extrusion, general extrusion as well as the projection operators. None of these seem to evaluate the BC correctly which includes evaluation of dependent variable at the boundary.
Would appreciate if someone gives me a hint and if I am on the right path to solve the problem.
Thank you
Vishnu
1 Reply Last Post 27 juin 2016, 08:54 UTC−4
Frank van Gool COMSOL Employee
Posted: 9 years ago 27 juin 2016, 08:54 UTC−4
Dear Vishnu,
If you want to use the value of the dependent variable on the same boundary, you can use it directly in the boundary conditions field.
Eg. you can prescribe a heat flux as "12*(293.15-T)" . T is then the temperature at that boundary.
You need an extrusion coupling only if you want to use the temperature at another boundary.
Frank
Dear Vishnu, If you want to use the value of the dependent variable on the same boundary, you can use it directly in the boundary conditions field. Eg. you can prescribe a heat flux as "12*(293.15-T)" . T is then the temperature at that boundary. You need an extrusion coupling only if you want to use the temperature at another boundary. Best regards, Frank
