PML in structural mechanics
Morten Wollert Nygren
Is there a way to make a PML in structural mechanics that will match all wavelengths, like the PML in acoustics?
3 Replies Last Post 13 déc. 2010, 16:28 UTC−5
Posted: 1 decade ago 26 nov. 2010, 17:48 UTC−5
No I do not know about that, but you could try to add some damping on your fixed parts with a boundary force
-k*u -damp*MyLambda
for eigenmodes set MyLambda variable to "lambda" of COMSOL, for frequency sweep try a
myLambda = -i*2*pi*freq
and repeat for v, w ...
however it will make your structure move in all directions
Hi No I do not know about that, but you could try to add some damping on your fixed parts with a boundary force -k*u -damp*MyLambda for eigenmodes set MyLambda variable to "lambda" of COMSOL, for frequency sweep try a myLambda = -i*2*pi*freq and repeat for v, w ... however it will make your structure move in all directions -- Good luck Ivar
Posted: 1 decade ago 13 déc. 2010, 10:13 UTC−5
Could you please elaborate a bit? I don't understand how I should implement this boundary force...
Is this a boundary force?
Hi Could you please elaborate a bit? I don't understand how I should implement this boundary force... Is this a boundary force?
Posted: 1 decade ago 13 déc. 2010, 16:28 UTC−5
first of all I have noticed that there are some PML BC's that appear time to time in the structural (v4) (depends on solver mode and on options installed), but I haven really looked into these as I'm not doing accoustic and have not seen any need to try PML's in structural so far.
What I was also saying is that you have the COMSOL implemented damping parameters (that you migh tune in at a given frequency) but you can also defne a "user" boundary load of the type -w*k[N/m] for a spring load along Z, as well as for an eigenfrequency solver a boundary load of load -w*damping[kg/s]*lambda for a damper (that by adapting the "damping" variable might be critical damping a motion at a given frequency). But dependingon your model I'm not sure its that easy to use these somewhat crudes methods. for a frequency sweep lambda is not defined, but you have "freq", and lambda = -i*2*pi*freq (if I have got that right, pls check carefully ;)
Hi first of all I have noticed that there are some PML BC's that appear time to time in the structural (v4) (depends on solver mode and on options installed), but I haven really looked into these as I'm not doing accoustic and have not seen any need to try PML's in structural so far. What I was also saying is that you have the COMSOL implemented damping parameters (that you migh tune in at a given frequency) but you can also defne a "user" boundary load of the type -w*k[N/m] for a spring load along Z, as well as for an eigenfrequency solver a boundary load of load -w*damping[kg/s]*lambda for a damper (that by adapting the "damping" variable might be critical damping a motion at a given frequency). But dependingon your model I'm not sure its that easy to use these somewhat crudes methods. for a frequency sweep lambda is not defined, but you have "freq", and lambda = -i*2*pi*freq (if I have got that right, pls check carefully ;) -- Good luck Ivar
