Rotating wave (restricted) flow around turbine blade
I'd like to do a simulation of a single turbine blade with a rotating wave flow.
I'm fairly new to COMSOL, and I expect a problem.
If I need to select an inlet and outlet in the environment, how am I supposed to create a flow that rotates 360 degrees around the turbine blade?
Is there perhaps a good way to implement this?
Thanks in advance,
1 Reply Last Post 8 janv. 2016, 10:53 UTC−5
François Mandias COMSOL Employee
Posted: 9 years ago 8 janv. 2016, 10:53 UTC−5
Dear Jorn,
I suggest you send an email to support@comsol.com with this case. Can you provide me your contactdetails.
François Mandias
Dear Jorn, I suggest you send an email to support@comsol.com with this case. Can you provide me your contactdetails. Best, François Mandias
