comsol vs matlab parameters
Posted 4 oct. 2010, 11:35 UTC−4 0 Replies
I have a question about passing argument from comsol to matlab when using Comsol with matlab.
to pass parameter with comsol, it is possible, as explainedin the documentation to use instruction like, for example,
model.param.set('side', '3.4');
where side is a parameter and 3.4 its value...the value can be subsequently varied if needed during parametric studies...as explained in the doc.
Note that in a "model.param.set" instruction only scalar can be passed according to the doc
but It is also possible to use
" side" defined as a matlab variable in other comsol instruction such as for eg
model.geom('geom1').feature('c1').set('r', side);
WITHOUT declaring it as a model.param
it works aparently the same
But in fact it is ALSO more powerful because you can pass more complexmatlab arrays like a list of coordinates, possibly of variable length to build for example a bezier curve whose structure and topology will then possibly evolve
In light of this I fail to understand the necessity of model.param... and why the doc does not mention this possibility of using directy matlab variables directly in comsol expression.
EXCEPT IF THERE IS SOME NON OBVIOUS PITFALL to this approach that i cannot see at the moment.
[I am still Young on my learning curve...]
So my question :
does any of you is aware or have experienced downside in using matlab variables in comsol expression in lieu of, apparently much more restrictive, comsol defined parameters??
needless to say, asmentionned above, that to the best of my knowledge, Comsol doc is mute on this subject... [ but I would love to be proven wrong on that..would make my life easier..]
JF
Hello Jean-Francois Leon
