Using the result of an integral in a different calculation
I would like to use the result of a integrated field (defined in Results->Derived values) in the calculation of a different quantity (for example, to obtain the result of the product of two different integrated values). It is easy to define a analytic function in Global definitons to calculate different quantities of the solved model, but when the calculation involves an integrated field, I cannot define it as an analytic function with the integration line and the function as parameters. Could you help me?
Thank you very much,
Iker.
0 Replies Last Post 4 oct. 2010, 09:59 UTC−4
Hello Iker Rodriguez
