3 oct. 2010, 08:12 UTC−4
well I tried to enteer your equations in V4.0a, blind without thinking too much, in coefficient and in general mode. I only set the system to linear, I left the rest as is and solved the two cases (you need to play a little with the solver settings when you mix two models like this and select the correct results.
The result are some "not very nice" oscillating graphs, and the oscillations arelinked to the mesh density, which indicates that something is wrong:
this is not an uniquely define BVP or a correctly set-up PDE.
So either I have missed a point,quite possible, or the equations cannot be solved like this
But we have discussed this before (with exaples) on the forum, see i.e. treads
(I havent found back the thread yet, it could have been about a year ago ;)
try a search on the forum
3 oct. 2010, 10:16 UTC−4
your problem cannot be solved because it have no solution!!
Indeed you have too many BC. you need 2 BC on;y to complete your system.
If you remove 2 Bc in order to get a well posed problem, then it will be very easily solved by comsol or any other ode package along the lines pointed out by Ivar.
JF
JF
5 oct. 2010, 04:23 UTC−4
Thanks a lot for your help, specially for your mph file. Your result computed by Comsol is similar with mine by matlab only. I has computed the question by two ways using matlab. One is the command of "slove", the other is finite-differential method with iterative technique.
The question raised in the subject is only a example to research the way compute by Comsol. In fact, the example means nothing in practice. The question I really want to solve is so complex that not suit to type here, so I educe the example above.
I will research the mph file carfully and search the BVP in the forum.
thank you again!
youf.
thank you again!
youf.
5 oct. 2010, 04:40 UTC−4
Thanks a lot for your answer. I am very sorry for the unclear illustration to the example which really means nothing in practice. However, I felicitate to myself that I has be guided by Ivar and you.
thank you again!
youf.
thank you again!
youf.
