Rigid body dynamics and fluid-structure interaction.
Is it possible to create a model that does the reverse of say a pump model, where instead of finding velocity fields based on the rotational velocity of an impeller, you can find the rotational velocity of the impeller based on a given inlet velocity? For example, lets say that I want to model the behavior of a box fan placed in a window on a windy day; the fan blades will rotate due to the inflow of air from outside. Could I find the rotational velocity of the fan blades given a specific wind speed?
If this is possible, what modules would work the best?
-Michael Petrarca
2 Replies Last Post 24 janv. 2011, 15:46 UTC−5
Hello Michael Petrarca
Posted: 1 decade ago 24 janv. 2011, 15:46 UTC−5
I don't have an answer to your question, but I have a question of my own. Can you show me a model of the first case: how to find velocity fields based on the rotational velocity of fan blades?
