How to measure the gain on an antenna in comsol?
Hi Folks,
I wanted to know how can i find the gain of an antenna. I am using one of the examples in comsol website, dipole antenna. Here is the link for it:
www.comsol.com/model/dipole-antenna-8715
How to measure tha gain in an specific direction?
I can see in the 2D polar plot, there is r maximum and r minumum, but i don't really know what does that mean.
Thank you.
Hadi Maghsoudiganjeh
4 Replies Last Post 7 juil. 2017, 23:04 UTC−4
Maxim Electromobility
Posted: 9 years ago 10 déc. 2015, 11:34 UTC−5
Hi Hadi,
following discussion might be interesting for you. It is quite old, however there is no build-in gain-variable implemented in comsol as far as I know.
www.comsol.com/community/forums/general/thread/20515/
Maxim
Hi Hadi, following discussion might be interesting for you. It is quite old, however there is no build-in gain-variable implemented in comsol as far as I know. http://www.comsol.com/community/forums/general/thread/20515/ Maxim
Posted: 9 years ago 13 déc. 2015, 02:15 UTC−5
Thank you Maxim! I found it.
There is an expression for gain under far field that gives the gain both in db and dbi.
Thank you Maxim! I found it. There is an expression for gain under far field that gives the gain both in db and dbi. -- Hadi Maghsoudiganjeh
Posted: 8 years ago 7 juil. 2017, 03:51 UTC−4
Updated: 8 years ago 7 juil. 2017, 03:52 UTC−4
Would you mind to share the equation to calculate the gain please as I have been facing the same issue as you had.
Many thanks,
Yang
Hello, Would you mind to share the equation to calculate the gain please as I have been facing the same issue as you had. Many thanks, Yang
Posted: 8 years ago 7 juil. 2017, 23:04 UTC−4
The recent versions of Comsol Multiphysics, RF module, actually do offer expressions for gain in the post-processing options. You can find additional information, including some discussion of the equations used, in the help system. Just search for it.
