phonon wave vector
Hi everyone
it is the first time for me to work on comsol and I want to calculate the phonon modes in nanowire but I don't know how to extract the wave-vectors corresponding to the eigenfrequencies of the phonon modes . and how to export that to matlab. If someone knows about that ,please help me
6 Replies Last Post 11 juin 2015, 02:18 UTC−4
Hello Hussein Ayedh
Posted: 1 decade ago 25 oct. 2010, 14:11 UTC−4
Have you had any luck? I am interested in this as well.
Seid Mohamadali Sadat
Posted: 1 decade ago 12 avr. 2012, 02:05 UTC−4
hi, could u find out how? I dont know how to define bloch boundary condition in solid mechanics physics.
Posted: 1 decade ago 12 avr. 2012, 22:28 UTC−4
You can manually define a Bloch boundary condition between two boundaries B1 and B2 by applying on boundary B1 a prescribed displacement of the form bndsim1(u)*exp(i*kx*L) where bndsim1() is a boundary similarity operator from Boundary B2. You should also specify that the displacement variables are complex and the Jacobian matrix is Hermetian.
Nagi Elabbasi
Veryst Engineering
You can manually define a Bloch boundary condition between two boundaries B1 and B2 by applying on boundary B1 a prescribed displacement of the form bndsim1(u)*exp(i*kx*L) where bndsim1() is a boundary similarity operator from Boundary B2. You should also specify that the displacement variables are complex and the Jacobian matrix is Hermetian. Nagi Elabbasi Veryst Engineering
Posted: 10 years ago 5 mai 2015, 06:58 UTC−4
I am trying to solve nanowire`s phonon dispersion.
But I have trouble in solving it.
I used 2D axis & 3D circular design. But I can not get satisfied results..
(I used structure mechanics -> solid mechanics & periodic condition.)
I don`t have clue what is problem..
I am trying to solve nanowire`s phonon dispersion. But I have trouble in solving it. I used 2D axis & 3D circular design. But I can not get satisfied results.. (I used structure mechanics -> solid mechanics & periodic condition.) I don`t have clue what is problem..
Posted: 10 years ago 6 mai 2015, 12:28 UTC−4
How is a continuum model going to give optical phonon modes? Seems at best you can get only a linear approximation for low-k.
Posted: 9 years ago 11 juin 2015, 02:18 UTC−4
I need to solve acoustic phonon modes & some lower optical modes.
If I use continuum model, I can not solve optical modes?
Could I know linear approximation setting method?
I need to solve acoustic phonon modes & some lower optical modes. If I use continuum model, I can not solve optical modes? Could I know linear approximation setting method?
