How can I input a heavy oil properties?
I am trying to use COMSOL to simulate a reservoir, but there is no related materials in library built-in.
For example, how can I input the saturation, permeability and temperature-dependent conductivity?
Whether can I use matlab to define the above properties?
or I should build a file with *.txt format then import it? If so, what kind of the txt file should be like?
Thank you very much.
1 Reply Last Post 20 sept. 2010, 05:40 UTC−4
Posted: 1 decade ago 20 sept. 2010, 05:40 UTC−4
try a piecevise funtion to define your parameters, this is described in the doc with a few examples
Hi try a piecevise funtion to define your parameters, this is described in the doc with a few examples -- Good luck Ivar
