Stop while solving
When I'm testing out new fluid flow models I plot the results while solving. If I see something happening that leads me to believe there is a modeling error, I stop the simulation, evaluate the model, make the changes and re-solve.
In 3.5a, the solution menu offered a "Stop" button for the solvers, in addition to a "Cancel" button for the entire solution. When the solvers were stopped in this manner, all previous time steps were available for post-processing.
In 4.0a, the only way I see to stop the simulation is to hit the "Cancel" button, which clears the solution completely.
Does anyone know a way to manually terminate a transient simulation and have the solution up to that point available for analysis?
1 Reply Last Post 15 sept. 2010, 16:21 UTC−4
Posted: 1 decade ago 15 sept. 2010, 16:21 UTC−4
If you'll vertically expand the region below the graphics window, you should see Stop buttons. To expand, put your cursor on the boundary between the graphics window and the region below it; the cursor changes to a double-headed arrow; click and hold the mouse while moving the arrow to a new position.
