10 sept. 2010, 05:19 UTC−4
first be sure you run the latest V4.0a patch 4.0.0.993 for me today, check the main COMSOL web sites for the updates
2nd not everything is translated corretly, as many names have changed, so older files might well need some tweaking.
I mostly translate an old file and start a new V4 session and then rebuild it in plain V4, by studying what the automatic translater did, applying it that way or using the new V4 features
10 sept. 2010, 15:00 UTC−4
Hi Ivar,
Thanks. I will run with latest patch and check. I will follow your second advise regarding building from scratch. Only problem will be related to the comsol's internal variable names. I hope they have kept the names same.
Regads,
Susant
Hi Ivar,
Regads,
Susant
11 sept. 2010, 07:06 UTC−4
Unfortunately, (but I can also say it's expected) the names are not all the same.
First of all they have changed the naming convention to the "structure" approach:
"solid.rho" (V4) instead of "rho_smsld" (V3.5) for the density "rho"
but then many "physical" variables have the same names, however there are many more, hence some corrections to avoid duplicates.
Turn on the equation view in V4, unfortunately we cannot sort the names alphabetically , nor C&P in the columns (would be nice and very helpful ;)
