Reaction Engineering Lab 3.5a --> data extraction?
I am new to working with COMSOL. So this might come off as simple question:
I ran a reaction kinetics model on the Reaction Engineering model and would like to retrieve the data points/values so I can plot them on excel and I am not sure how to do that. If anyone has been able to export more than just images of the plotted data from the Reaction Engineering Lab please let me know how you went about this.
Thank you,
Samar
2 Replies Last Post 5 sept. 2010, 14:33 UTC−4
Posted: 1 decade ago 5 sept. 2010, 11:41 UTC−4
for info in V4 you have a predefined export to excel fo table output.
In V3.5 you can export plot info via the plot window export (as text or csv).
But the mots flexible way is via Matlab, and then directly work on the "fem" structure with the COMSOL matlab routines (see the doc commend.pdf)
Hi for info in V4 you have a predefined export to excel fo table output. In V3.5 you can export plot info via the plot window export (as text or csv). But the mots flexible way is via Matlab, and then directly work on the "fem" structure with the COMSOL matlab routines (see the doc commend.pdf) -- Good luck Ivar
Posted: 1 decade ago 5 sept. 2010, 14:33 UTC−4
Thank you for the insight. I found the solution.
Samar
Thank you for the insight. I found the solution. Samar
