Question about Permeability Units
My model contains a porous membrane which I am trying to characterize (permeability and porosity) with physiological values. When characterizing the porous membrane, COMSOL asks for permeability units of m^2; however, in all of the papers that I've looked at to find physiological values, their units of permeability have been cm/s. I've found some other information on converting from hydraulic conductivity (cm/s) to permeability (m^2) but I'm not sure how relevant it is. Does anybody have experience with trying to convert these units and if so, what did you do?
Thank you.
2 Replies Last Post 30 déc. 2016, 16:08 UTC−5
Hello Elizabeth Walker
Posted: 9 years ago 30 déc. 2016, 13:29 UTC−5
I saw the Brinkman equation, in which 'k' is the permeability tensor with m^2 unit. If you search permeability tensor in Google, you will get 'Permeability (earth sciences)' wikipedia link, in this m^2 unit is given.
But I am also not cleared about how to convert m/s or cm/s unit to m^2 unit, because both are the permeability unit and both are contradicting also.
Hi I saw the Brinkman equation, in which 'k' is the permeability tensor with m^2 unit. If you search permeability tensor in Google, you will get 'Permeability (earth sciences)' wikipedia link, in this m^2 unit is given. But I am also not cleared about how to convert m/s or cm/s unit to m^2 unit, because both are the permeability unit and both are contradicting also.
Posted: 9 years ago 30 déc. 2016, 16:08 UTC−5
Often permeability and hydraulic conductivity are mixed up.
The unit of intrinsic permeability is m^2 and that of conductivity is m/s.
To convert m^2 into m/s you multiply permeability (m^2) with rho*g_const/mu, where rho (kg/m^3) is liquid density, g_const (m/s^2)is the internal variable within comsol for gravity and mu (kg/m/s) is the dynamic viscosity.
Suresh
Hi, Often permeability and hydraulic conductivity are mixed up. The unit of intrinsic permeability is m^2 and that of conductivity is m/s. To convert m^2 into m/s you multiply permeability (m^2) with rho*g_const/mu, where rho (kg/m^3) is liquid density, g_const (m/s^2)is the internal variable within comsol for gravity and mu (kg/m/s) is the dynamic viscosity. Suresh
