Problem with Transport of diluted species concentration calculation
Posted 1 sept. 2015, 22:41 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 4.4 0 Replies
For a certain mesh size, the problem seems to match the theoretical output concentration with relative errors lower than 4%. In order to increase solution accuracy i had reduced evem more the mesh size. For the new mesh size i had almost 1,5 millions DOFs.
The new model was solved out in 17 hours. Surprisingly, for the new results, the output concentration was much lower than the previous ones and hince the error relative to the theoretical values.
i was thinking that decreasing mesh size would improve the simulation accuracy, not make it worst.
Could someone please wive me and idea about what should be happening and what should i do to fix it?
thank you very much
Hello Houari Cobas
