parametric distribution
Is there anyway that I can define a spherical geometry with a Gaussian distribution of a Parameter inside it?
Haleh
1 Reply Last Post 1 sept. 2015, 16:48 UTC−4
Posted: 10 years ago 1 sept. 2015, 16:48 UTC−4
you cannot exactly do it with a parameter, but you can define a variable:
This would center the Gauss distribution var with width sigma at the origin. Define a variable like this in the entire model or in the spherical domain and you can use it wherever you need it in your model settings.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, you cannot exactly do it with a parameter, but you can define a variable: [math]var = \frac{1}{\sigma \sqrt{2 \pi}}e^{-\frac{1}{2}\left(\frac{x^2 + y^2 + z^2}{\sigma^2}\right)}[/math] This would center the Gauss distribution var with width sigma at the origin. Define a variable like this in the entire model or in the spherical domain and you can use it wherever you need it in your model settings. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
