Reducing computation time of model by splitting about symmetry plane - help needed
Sathya Sai Seetharaman
I am doing a model where I want to compute the eigen solutions of a system of two coupled split-rings at different separation distances. In order to reduce computation time, i have split the system in half about the symmetry plane (the plane that would cut the rings in half about the splits). So the PML is halved too. I have built this model in geometry, added materials of the system (assuming rings made of copper, don't want PEC for this model as I want to make comparison with my experiments), assigned far-field scattering, impedance boundary and other necessary conditions to model. The problem is that I am unable to choose the outermost boundaries of PML to "Scattering Boundary Condition" as they display 'Not Applicable'.
(1) Can someone please help me fix this issue by explaining what I did wrong?
(2) Is there a symmetry condition that I need to add to the model to let COMSOL know that I have split the model only to reduce computation time?
Please find the model attached. Thank you in advance.
2 Replies Last Post 2 sept. 2015, 04:45 UTC−4
Posted: 10 years ago 1 sept. 2015, 18:54 UTC−4
You don't seem to have included the PML domains in your computational space. In the Model Builder, if I click on the Electromagnetic Waves, Frequency Domain (emw) there, all it shows is domain number 3.
Posted: 10 years ago 2 sept. 2015, 04:45 UTC−4
Hi Robert,
Thank you for your response.
Edited response: After you mentioned it, I clicked Electromagnetic Waves, Frequency Domain (emw) and under Domain Selection, I chose 'All Domains'. Now all the domains are included and I am able to choose Scattering Boundary Condition. I'll post again if I run into any other issues. Thank you once again.
Sathya.
Hi Robert, Thank you for your response. Edited response: After you mentioned it, I clicked Electromagnetic Waves, Frequency Domain (emw) and under Domain Selection, I chose 'All Domains'. Now all the domains are included and I am able to choose Scattering Boundary Condition. I'll post again if I run into any other issues. Thank you once again. Regards, Sathya.
