plot 3d surface image
Dear all,
I have built an 3d RF geometry and excited it with light. By plotting the electric field surface on this geometry, I want to display the surface without built-in electric field applied on the air. I should make transparent this boundaries. Which toolbar and properties should be configured?
Thank you very much in advance,
1 Reply Last Post 23 août 2015, 11:16 UTC+2
Posted: 10 years ago 23 août 2015, 11:16 UTC+2
Dear all,
I have found some useful materials in The Comsol Blog
www.comsol.com/blogs/the-graphics-window-effective-beautiful-postprocessing/
www.comsol.com/blogs/surface-volume-line-plots-visualizing-results-heat-sink/
If you need to plot your results without some boundaries,edges or domains, this will help you
Dear all, I have found some useful materials in The Comsol Blog http://www.comsol.com/blogs/the-graphics-window-effective-beautiful-postprocessing/ http://www.comsol.com/blogs/surface-volume-line-plots-visualizing-results-heat-sink/ If you need to plot your results without some boundaries,edges or domains, this will help you
