Interior boundaries check boc
I kindly would like to ask why interior boundary check box exists?
When it is clicked what it means. When it is not clicked and we can not select some "boundary selection", what does it means?
For example,
If at example Piezoelectric Shear Actuated Beam we do not click the check box what will go wrong
I have an intuition but i can not explain it correctly.
i searched the pdf's for it but i couldn't make out why is that.
Thanks in advance
Ilias
2 Replies Last Post 22 août 2010, 18:24 UTC−4
Posted: 1 decade ago 22 août 2010, 16:29 UTC−4
For example,
Thanks in advance
Ilias
Hi Ilias,
Interior boundary means that you are inside the same physical domain, which usually means continuity in FEM, and you want to impose a different boundary condition on it. So, normally you should not check it, unless you want to apply a special boundary condition to a boundary that usually is left alone.
[QUOTE] Hi, I kindly would like to ask why interior boundary check box exists? When it is clicked what it means. When it is not clicked and we can not select some "boundary selection", what does it means? For example, If at example Piezoelectric Shear Actuated Beam we do not click the check box what will go wrong I have an intuition but i can not explain it correctly. i searched the pdf's for it but i couldn't make out why is that. Thanks in advance Regards, Ilias [/QUOTE] Hi Ilias, Interior boundary means that you are inside the same physical domain, which usually means continuity in FEM, and you want to impose a different boundary condition on it. So, normally you should not check it, unless you want to apply a special boundary condition to a boundary that usually is left alone.
Posted: 1 decade ago 22 août 2010, 18:24 UTC−4
Very grateful for your response Danial. Understandable explanation
