Josh Thomas
Certified Consultant
9 years ago
30 juil. 2015, 10:20 UTC−4
Hamid-
The initial time step size is dependent on the total time request (in your case, 400 seconds or 100 seconds). The initial step size can have an effect on the accuracy of the returned results.
For a one-to-one comparison and to confirm this is the issue you can try to fix the initial step size to make it the same for both cases (override the default initial time step size).
If indeed this is the issue, you may try selecting Time Stepping method as Strict rather than Free and selecting a smaller time step in your time range request. This will force the solver to be more accurate. You can also try tightening the absolute and relative tolerances for your problem. This should cause the 2 cases you described to converge to the same answer.
Josh Thomas
AltaSim Technologies
Hamid-
Josh Thomas
Josh Thomas
9 years ago
30 juil. 2015, 10:22 UTC−4
You may also check that the initial values for dependent variables is the same in both cases. Sometimes if you re-solve a previously solved model the legacy solution is defaulted to the initial values for the subsequent solution.
Josh Thomas
Josh Thomas
9 years ago
31 juil. 2015, 04:01 UTC−4
Dear Josh
in fact, the range of my initial problem is (0,0.05,100) after that when I try to see what happens after 100 seconds, I compute the same problem and letting everything unchanged for (0,0.05,400) the solution is totally different. consider a channel for example when I compute the problem for (0,0.05,100) the direction of the flow is from left to right and when I compute the same problem for (0,0.05,400) the flow direction is from right to left. I changed the time stepping method from free to strict but nothing changed. what is your advice?
Thank you very much
Dear Josh
Thank you very much
Josh Thomas
9 years ago
31 juil. 2015, 09:25 UTC−4
Hamid-
I would check the other suggestions I gave in my previous posts specifically:
1) Fix the initial time step for both cases. Compare results. If changing to "strict" doesn't affect answer you may also need to decrease the time step request (currently 0.05).
2) Have you confirmed that the initial values of variables solved for is the same in both cases? You can check this by using the "Get initial values for step" option instead of "compute".
You can also post your model if you want people to get a better look at it.
Josh Thomas
Hamid-
Josh Thomas
