Current through a twisted pair
I have a model of a twisted pair of wires, and I would like to run a current through each wire. However, I'm unable to select the right boundaries for the ground and terminal.
Could anybody help with this problem? I've attached the model.
Thanks in advance!
1 Reply Last Post 22 juil. 2015, 08:52 UTC−4
Posted: 9 years ago 22 juil. 2015, 08:52 UTC−4
Just looking at your model very briefly, you will need to have the wires touch the sides of the airbox in order to complete the return paths. You have them hanging out of the airbox which is not going to be correct. With the chosen physics, for exciting the wires you can use a lumped port. Check some of the other AC/DC or RF module files. While they may not address your specific problem they will address setup if you study them. Ground can be achieved by using the airbox sides so you don't really have to set up the ground specifically. If you change to a different physics that may no longer be true.
