                                2 decades ago
                                16 août 2010, 05:25 UTC−4
I can only dvice you to ask also "support", but document well your case and give them the models so they can quickly reproduce the issue
                                2 decades ago
                                16 août 2010, 08:46 UTC−4
Hello!
I want to be able to modify the geometri by alterning the some constants in a m-file.
for exemple instead of entering the number 0.048 i want to create a constant, like
width=0.048;
But as soon as i put width instead of a number, matlab can run the last line?!  why?
I tryed all diffrent ways. This did work in the old version 3.5 but I can't understand how in version 4?
% Geometry of a Rectangle
model.geom('geom1').feature.create('r1', 'Rectangle');
model.geom('geom1').feature('r1').setIndex('size', '0.048', 0);
model.geom('geom1').feature('r1').setIndex('size', '0.138', 1);
model.geom('geom1').feature('r1').set('base', 'center');
model.geom('geom1').feature('r1').setIndex('pos', '0.024', 0);
model.geom('geom1').run('r1');
Have a nice day
what is the error you're getting? the above code ran fine for me.
                            [QUOTE]
Hello!
width=0.048;
Have a nice day
[/QUOTE]
                                2 decades ago
                                16 août 2010, 09:14 UTC−4
                                                    Hi! yes, that code woks good untill I exchange the number 0.048 with a constant, like a,
so if I write
%Constants
a=0.048
model.geom('geom1').feature('r1').setIndex('size', 'a', 0);  % Put in the constant instaed of 0.048
MATLAB says:
??? Java exception occurred:
Exception:
	com.comsol.util.exceptions.FlException: Unknown model parameter
Stack trace:
	at com.comsol.nativeutil.properties.Property.a(Unknown Source)....
Shoulden't this be working?? And I have tryed without the '  '.
regards
Olivia
so if I write
%Constants
a=0.048
MATLAB says:
Exception:
Stack trace:
regards
Olivia
                                2 decades ago
                                16 août 2010, 10:02 UTC−4
                                                    Hi Olivia,
Did you define it first in the global parameters section?
i.e.
model.param.set('a','0.2');
                            Hi Olivia,
i.e.
