Concentration at outlet of a tubular reactor
Hi all,
I am simulating a tubular reactor in 2-D axial symmetry. I am having problems in finding reactant concentration at outlet. I have coupled mass and momentum balances equations to characterize the flow.
The flow was considered to be fully developed and Newtonian. So i a have used the following equation for determination of velocity
2*v0*(1-(r/R1)^2)
v0=initial velocity
1 Reply Last Post 13 juil. 2015, 02:52 UTC−4
Posted: 10 years ago 13 juil. 2015, 02:52 UTC−4
Derived values --> Point evaluation/Surface integration --> min/max/average.
You can also define a slice plot, setting a slice at the outlet. Or you can define a 3d cut place at the outlet.
Is this what you asked?
br
Lasse
Derived values --> Point evaluation/Surface integration --> min/max/average. You can also define a slice plot, setting a slice at the outlet. Or you can define a 3d cut place at the outlet. Is this what you asked? br Lasse
