Thermal Lensing
Posted 17 juin 2015, 03:15 UTC−4 Heat Transfer & Phase Change, Structural Mechanics Version 5.0 1 Reply
I am trying to simulate thermal lensing and focal shift for laser systems. I started with the library example "Thermally Induced Focal Shift Application ID: 19955". It is a very nice example as a starting point but somehow I realized that when I am inserting another transparent object after the lenses( I inserted a slab in) all rays stops on that new object as if it is a wall. I checked every node to set it correctly as a transparent object but there is no solution for that. Actually if you don't use mirroring for the two lenses but create them seperately rays doesn't go inside the second one, I also tried that. I think there happens a problem in the solver settings. Can you help me with that?
1 Reply Last Post 19 juin 2015, 01:31 UTC−4
