10 years ago
27 mai 2015, 10:31 UTC−4
Would using a contact pair work here? Define the source as the membrane and the destination as the top surface of the substrate.
10 years ago
28 mai 2015, 15:13 UTC−4
Yes. I have tried adding contact pair. But once the pressure is high enough that it make the beam contact, the simulaiton starts doesn't converge. It seems like there is still some mistake. I have attached the simulation file build on comsol 4.4. Any sugestions on how to fix the convergence issue? Or if i made any mistakes in the simulation model?
9 years ago
7 juin 2016, 13:22 UTC−4
I know this post is a year old so it's a long shot, but did you by any chance find a way to solve your problem? I'm encountering the same issue, where the simulation won't converge when using contact pairs.
I think the main problem is the fact that the surfaces aren't touching initially, and also that the area of surface contact is always changing as the membrane is pushed against the substrate.
If anyone has a solution to this problem, it would be greatly appreciated.
Thank you
Thank you
