Dielectric Barrier Discaharge example
Posted 17 mai 2015, 15:45 UTC−4 Plasma Physics 0 Replies
1. suppose the dimension in pdf model as 1mm for dielectric thickness ,2mm for gap discharge and 10 cm for dielectric diameter my Question why these dimensions are different in example of program to 0.1 mm dielectric thickness ,0.2mm for gap discharge and dielectric diameter as same 10 cm?
2. the Argon breakdown in Experiments practice usually at atmospheric pressure is 2000 volt for dielectric barrier discharge and frequency is RF while in the the example models.plasma.argon_dbd_1 is 750 volt with frequency 50 KHz ? How can we confirm the authenticity of the simulation ?
Hello Zainab Dakheel
