9 years ago
20 avr. 2015, 16:14 UTC−4
I was waiting for someone to answer this, but what I can add is there's generally two ways to determine resistance:
1. to solve a stationary problem with a small bias, solving current, and then take the ratio of voltage to current, taking care to adjust for if you've used any symmetric boundaries (eg simulating 1/2 the structure means you need to divide the resulting ratio by 2).
2. to do a small-signal analysis and find the admittance term for one of the terminals @ DC at zero bias. The resistance = 1 / the admittance. Again you need to adjust for any symmetric boundaries.
Maybe someone else can give more information.
9 years ago
21 avr. 2015, 05:06 UTC−4
Dear Daniel
thanks for your reply.
Actually I have a simple DC Model (a cylinder), calculating the resistance exactly as you said like taking the ratio of voltage to current and then comparing the result with my analytical calculations.
However, I am interested in trying out the same model in different physics in order to find out the probable changes in the resistance value.
so you suggest trying the signal analysis rather than (es)?
[QUOTE]
[/QUOTE]
Dear Daniel
9 years ago
21 avr. 2015, 09:58 UTC−4
In the resistor library example there's a parameter: ec.R11 which is the resistance extracted using small-signal analysis. This is the small-signal resistance of contact 1.
9 years ago
23 avr. 2015, 05:09 UTC−4
Good point. Thanks Daniel ;)
9 years ago
24 avr. 2015, 05:58 UTC−4
Hello again Daniel :)
just one more question! :)
you know I only have the option of calculating the parameter ec.R11, when I have the ground as boundary condition.
can't we calculate it when having a positive and negative Voltage terminals?
9 years ago
24 avr. 2015, 14:39 UTC−4
The meaning of R11 in the AC sense is ∂V1 / ∂I1 with all other terminals held constant. This is presumably 1 / ( ∂I1 / ∂V1) with all other terminals held constant. It's a small signal determination, operating on incremental changes, and so the voltage on other terminals as long as those nodes is constant doesn't matter.
Resistance (and admittance) are matrixes, so you can also calculate, for example, gmn ≣ ∂Im / ∂Vn for terminals m and n. That means if I change the voltage on terminal n with all other terminals held constant than what is the change in the current at terminal m. An example is transconductance in transistors.
