Is there a way to copy a solution, modify it into new solutions and plot them on the same geometry objects?
Posted 9 avr. 2015, 11:42 UTC−4 0 Replies
I have a question. Suppose that I have 3 objects, called A,B,C which are the same, then I set the physic "heat transfer in solid" to A and solve the problem and get the solution called uA. And, I know the relation between uA, uB, uC such as:
uB = b*uA
uC = c*uA
where b and c are given constants.
So that, I do not want to repeat the same approach to find solutions uB and uC, is there a way to copy the solution uA, and modify them into uB, uC (base on the relations) and then plot them into B and C ?
Thank for consider my problem.
Hello Duy Duc Nguyen
