30 juin 2010, 15:52 UTC−4
Ifit's in 3.5 (as I havent checked yet in V4) and you write correctly in COMSOL language with * it shoudl work to replace the viscuasity constant by your formula. If you also use a 2 pase field that is defined by some spatial coorinates you must multiply by some bolean equations()or perhaps the if works too) to tell where to switch from one to the other, no ?
Have fun Comsoling
Have fun Comsoling
30 juin 2010, 18:36 UTC−4
thanks Ivar , is there any documnts about how to use 'if' in comsol i am useing 3.5a
thanks again
thanks again
2 juil. 2010, 02:51 UTC−4
Hello
I beleive it's in the command.pdf, but its just the syntax, else use the boleans i.e. *(x<0) which is =0 false and 1 true (I believe)
Hello
2 juil. 2010, 18:22 UTC−4
thanks alot ...i will try it
