Chemical Reaction Engineering problem: concentration of products is too high
Hello everyone
I guess I have a simple problem but I don't know what I'm doing wrong.
When I've got a simple reaction, sth like:
x => 2z
and I enter an inital value for the concentration of x=1 mol/m^3, I have the following problem:
When comsol plots the concentration over time I get a maximal concentration of 2 mol/m^3 for z but that's impossible. The concentration of the product can't be higher than the concentration of the reagant.
How can I fix this?
Thanks for the help
3 Replies Last Post 31 mars 2015, 11:30 UTC−4
Posted: 1 decade ago 31 mars 2015, 09:07 UTC−4
Yes it can, you have the stoichiometric coefficient 2, i.e. each x produces 2 z.
Posted: 1 decade ago 31 mars 2015, 09:48 UTC−4
Hi Lasse,
thank you for your reply.
I think I had an understanding problem. I thought the maximum concentration could only be 1 mol/m^3 if thats the concentration of the reagent. But it makes sense, that the concentration of z is 2 times because for 1 molecule x there will be two z, if I understood it correctly.
I appreciate your help.
br
Hi Lasse, thank you for your reply. I think I had an understanding problem. I thought the maximum concentration could only be 1 mol/m^3 if thats the concentration of the reagent. But it makes sense, that the concentration of z is 2 times because for 1 molecule x there will be two z, if I understood it correctly. I appreciate your help. br
Posted: 1 decade ago 31 mars 2015, 11:30 UTC−4
Mass of the material does not naturally change, but in chemistry we are counting mols that are not absolute in the sense that when talking about them you have to define which compound you are talking about. Yet, mol is needed because substances react in integer ratios of mols.
