Using Time-dependent vs Frequency study for single DC pulse
Good day,
I am modelling a scenario where a single 100 microsecond DC pulse is passed through a coil. Is it better to use a Time-dependent study or a frequency study set to 10000Hz to model the eddy currents and the skin effect?
3 Replies Last Post 16 juin 2016, 05:21 UTC−4
Posted: 10 years ago 7 mars 2015, 20:44 UTC−5
Hi:
for your question,Maybe you can use the transient solution,and You should define a time pulse function as your input.
Hi: for your question,Maybe you can use the transient solution,and You should define a time pulse function as your input.
Posted: 9 years ago 25 sept. 2015, 01:59 UTC−4
which field shoud i use, i want to simulate the skin effect but with high frequency pulse DC power
Posted: 9 years ago 16 juin 2016, 05:21 UTC−4
Have you solved the problem? My study has also such an exicitation.
