COMSOL Failed to find a solution error
I am getting an error message:
Failed to find a solution.
Maximum number of Newton iterations reached.
- Feature: Stationary Solver 1 (sol1/s1)
This message comes whenever I increase the density of the liquid in a simple laminar fluid flow in channel. I have volume forces in a certain part of the channel.
Is there a way to avoid getting this message?
1 Reply Last Post 6 mars 2015, 15:08 UTC−5
Posted: 1 decade ago 6 mars 2015, 15:08 UTC−5
I had the same error when using COMSOL and still struggled with it. But you can have a try on changing the maximum iteration number in the solver settings.
xinyao Tang
I had the same error when using COMSOL and still struggled with it. But you can have a try on changing the maximum iteration number in the solver settings. -- xinyao Tang
