How to calculate the force on a permanent magnet due to surrounding winding current
Posted 4 mars 2015, 12:56 UTC−5 Low-Frequency Electromagnetics 1 Reply
                                                    This should be a simple model, but I am very new to comsol and cannot find the relevant tutorials.
I have a permanent magnet, then an air gap, then a coil going around the permanent magnet.
To model this I have created three rectangular geometries next to each other. The furthest left will be the permanent magnet, the middle is air, and the furthest right is copper. I have added an axial symmetry to the left boundary of the magnet. This means the copper surrounds the magnet with an air gap between.
I have added an external current to the copper domain, with a current density in the direction phi. This means the current goes around the copper ring. This simulates a multi winding coil with a current going through it.
My Question
How do I turn the furthest left rectangle into a permanent magnet, and how do I calculate the force on it? Eventually I want to move the magnet up and down into different positions and calculate the force as a function of distance. But for now just calculating the force on the magnet from the electric field generated by the coil is enough.
My Question
1 Reply Last Post 4 mars 2015, 16:24 UTC−5
