Integrating over an arbitrary line
I have a 3D model that I need to integrate temperature along the line between two points. I have a formula that depends on the integral of temperature and need to compute this formula for a number of distinct lines. I would like to perform the integration and obtain the formula solution within Comsol. I currently perform postprocessing to get the temperature between two arbitrary points, export the data, and perform the integration and formula computations outside of Comsol.
With Integration Coupling Variables, Comsol will integrate temperature over an edge, but not an arbitrary line that is not part of the object's geometry. I can subdivide my object to have edges where I need to evaluate the temperature integral but that complicates my geometry and mesh. Is there another way?
Thanks for the help.
Mike
1 Reply Last Post 29 août 2009, 22:47 UTC−4
Posted: 2 decades ago 29 août 2009, 22:47 UTC−4
Mike:
There may be another way, but I know you can add lines to 3D models without subdividing the volumes into multiple domains. Just use Draw-->Line, and enter the starting and ending coordinates for your line. In most cases, the presence of a few extra lines here and there crossing the model won't drastically change the number of mesh elements, and then you can use the standard tools for evaluating the integrals along them.
Mike: There may be another way, but I know you can add lines to 3D models without subdividing the volumes into multiple domains. Just use Draw-->Line, and enter the starting and ending coordinates for your line. In most cases, the presence of a few extra lines here and there crossing the model won't drastically change the number of mesh elements, and then you can use the standard tools for evaluating the integrals along them.
