Edgar J. Kaiser
Certified Consultant
9 years ago
18 févr. 2015, 05:07 UTC−5
Hi Lasse,
I tested that with two of my recent models. One is 160 MB with solution. After clearing solutions and meshes it is 0.7 MB. The other smaller one is 16 MB with solution and 92 kB with cleared solutions and meshes.
So it is not that bad. A bit mysterious why your 10 MB model isn't shrinking by clearing the solution?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Lasse,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
9 years ago
18 févr. 2015, 05:39 UTC−5
You just deleted the data set, or is there some other operator?
Lasse
Lasse
9 years ago
18 févr. 2015, 05:48 UTC−5
OK
I studied the problem a bit further: Deleting the Data Set does not remove it. If I right click the Result node again, I can recover my solution. Hence, it was never gone. How is it deleted for good?
Lasse
OK
Lasse
Edgar J. Kaiser
9 years ago
18 févr. 2015, 06:47 UTC−5
It is in the ribbon under the 'Study' tab. Deleting the dataset is not the best idea because it also deletes the corresponding result nodes.
Edgar J. Kaiser
www.emphys.com
Edgar J. Kaiser
9 years ago
18 févr. 2015, 06:56 UTC−5
Thanks! Apparently I am not yet familiar with Comsol 5...
Lasse
Lasse
Jeff Hiller
COMSOL Employee
9 years ago
18 févr. 2015, 10:55 UTC−5
Hi Lasse,
Besides clearing all solutions (in the study ribbon), you can also clear all meshes (in the mesh ribbon), to make the file as small as possible.
Hi Lasse,
8 years ago
22 déc. 2016, 14:04 UTC−5
Thanks Jeff for the mesh clear tip, that helped save some size for my model. One data point in comsol 5.2: for a model starting out at 10.3 MB, it got down to 4.9 MB from "clear solutions" and to 4.1 MB with "clear mesh". Other things I tried past that point only shaved of a few kB. So it seems the 2 things to do are clear solutions and mesh. One button for this sequence would be nice...
