Importing point measurements (coordinates in xyz format) into COMSOL 5.0
Posted 13 févr. 2015, 16:41 UTC+1 Fluid & Heat, Results & Visualization Version 5.0 5 Replies
Hi all,
I am wondering if it is possible to import point measurements into COMSOL. I have a whole range of flow velocity and depth measurements for a river structure. I have already created the 3d geometry drawing in COMSOL, and would like to import my .txt file with these two measurements per point (only one velocity and one depth measurement per point-location, no repeats, a total of 150 point-locations for this structure), so that I can create a colored visualization of flow velocity and depth profile of this structure.
How exactly should the .txt file be ordered? First column with x coordinates, then y, then z, then measurements?
Can I then import it into COMSOL 5.0 via functions - interpolation? How will post-processing for this work exactly?
I only recently started using COMSOL, and any help would be greatly appreciated.
Thank you,
Jeroen
Thank you,
Jeroen
5 Replies Last Post 24 févr. 2015, 13:32 UTC+1
