probe variable problem
I defined a domain point probe (Temperature)and the model runs fine and I get a table of the temperature at specified times.
But if I try to define a variable with an expression that includes the probe variable and run the model I get an error message saying it does not recognize the probe variable. Is there some way to define an initial value for the probe variable? What am I doing wrong?
thanks for your help
David
2 Replies Last Post 13 févr. 2015, 05:04 UTC−5
Posted: 10 years ago 12 févr. 2015, 04:42 UTC−5
What do you try to probe? Whats is the unknown variable? Is there, say, a constant parameter which is not declared before running the simulation?
Lasse
Hi What do you try to probe? Whats is the unknown variable? Is there, say, a constant parameter which is not declared before running the simulation? Lasse
Posted: 10 years ago 13 févr. 2015, 05:04 UTC−5
OK thanks, I found the problem, I defined the variable in the Global variables instead of the modelvariables
