warning: Inconsistent pointwise non-ideal constraints found.
Posted 1 juin 2010, 11:24 UTC−4 13 Replies
4 constraints are merged/removed.
Many thanks
Hello Danial Tz
It gets annoying as all the log file is filled with these messages. The simulation runs normal though.
Warning: New constraint force nodes detected: these are not stored !
Anyone?
I have been off comsol for a while now [ still have to move to 4.0] but I remember having these kind of warning when my constraint were not properly defined [ weak ideal non ideal.. ] with 3.5
So it is most probably the same things.. you need to clearly understand which type of constraint to use for a given problem .. and it is not easy .. [ to be honnest at the beginning I tried all possible combinations untile these warning messages disappeared.. again this come from my experience with 3.5...
hope this will help anyway
jf
jf
Hi Jean Francois,
Yes, you are correct for Comsol 3.5. The problem is that in Comsol 4 this is the error you get when using FSI module, and nothing else. It gives the error on the FSI boundaries.
Comsol 4.0a, 4.1
Ubuntu 10.04.1
Inconsistent pointwise unidirectional constraints found.
This is what it's saying in Comsol 4.1. I am just using a simple fsi boundary condition. Doing nothing special.
Comsol 4.0a
Ubuntu 10.04.14
I personally got this message when using symmetries.
sirisha
and this one:
Anyone?
If this is still an issue, then Please see www.comsol.com/support/knowledgebase/1056/
I am still searching for an answer for the pointwise constraints.
sirisha
Naturally, I suspect that the failure is related to this issue...
It could be but the chances are higher that its related to a too large mesh deformation issue, which often participate to trigger these warnings. Have you set the model to plot while solving so you see what is happening, often you need to track the mesh quality, as well as a few probe values in FSI issues
Suggested Content
- KNOWLEDGE BASE Warning: New Constraint Force Nodes Detected
- FORUM Difference between Ideal and Non-Ideal constraints??
- BLOG What Happens If I Use 2 Different Unit Systems in 1 Simulation?
- BLOG Methods for Dealing with Numerical Issues in Constraint Enforcement
- BLOG Understanding Stabilization Methods
