Evaluate derived values
In the Results node, I would like to evaluate several expressions of derived values simultaneously in the same table. For example, I have to evaluate the Surface Maximum of stresses sx, sy and sz and I would like to obtain each one in a column in the same table, without creating a distinct subnode "Surface Maximum" for each expression.
Thank you in advance.
1 Reply Last Post 2 mars 2015, 11:33 UTC−5
Posted: 10 years ago 2 mars 2015, 11:33 UTC−5
Hello Mohamed,
You can certainly do that. Click on the little black triangle next to the word "Evaluate" at the top of the Settings window to select whether you want the quantity evaluated in a New Table (the default) or an existing one.
Hello Mohamed, You can certainly do that. Click on the little black triangle next to the word "Evaluate" at the top of the Settings window to select whether you want the quantity evaluated in a New Table (the default) or an existing one. Best, Jeff
