Introduce a new equation
I'm working with the comsol and I want to introcude a new equation for calculate the potencial in a Battery.
The equation is like this:
E = E1 + A * Log(c_A*(6800-c_A)/c_B)
Where E1 and A are constant and c_A, c_B are output variables concentrations of the other equation (Convention and Diffusion),
So I need this for calculate E, but i don't know how can i do it. I'm triying to work woth the PDE equation but is not working.
I'll really apreciate your help
regards
Pablo
6 Replies Last Post 28 mai 2010, 11:43 UTC−4
Posted: 1 decade ago 28 mai 2010, 08:01 UTC−4
How about entering them in Scalar expressions? Options -> Expressions -> Scalar expressions
once you entered, update your model (under Solve menu)
How about entering them in Scalar expressions? Options -> Expressions -> Scalar expressions once you entered, update your model (under Solve menu)
Posted: 1 decade ago 28 mai 2010, 10:23 UTC−4
The problem is that i need to introduce this equation and obtain the visual representation of this equation in all of the material.
I don't know if that is possible only with the scalar equation because I don't find this variable in the plot parameters.
what can i do?
The problem is that i need to introduce this equation and obtain the visual representation of this equation in all of the material. I don't know if that is possible only with the scalar equation because I don't find this variable in the plot parameters. what can i do?
Posted: 1 decade ago 28 mai 2010, 10:43 UTC−4
Then define it in subdomain expressions, and just write the variable in the surface plot manually; if I got you correctly.
Posted: 1 decade ago 28 mai 2010, 11:18 UTC−4
Write the variable in the surface plot manually?
How can i do that?
Write the variable in the surface plot manually? How can i do that?
Posted: 1 decade ago 28 mai 2010, 11:27 UTC−4
well, let's say I have a variable called reaction_rate, which is equal to c*k, where c is the concentration and k a constant.
Write reaction_rate = k*c in the subdomain expression. Then update your model through solve menu. Next, type reaction_rate in the surface plot where the expression box is.
well, let's say I have a variable called reaction_rate, which is equal to c*k, where c is the concentration and k a constant. Write reaction_rate = k*c in the subdomain expression. Then update your model through solve menu. Next, type reaction_rate in the surface plot where the expression box is.
Posted: 1 decade ago 28 mai 2010, 11:43 UTC−4
Thanks a lot for your help!!
The program is running in this seccion now.
regards
Pablo
Thanks a lot for your help!! The program is running in this seccion now. regards Pablo
