Material Overview shows a stop sign
Hi all,
I am having a problem when setting several materiales to my model.
When I do so, there is a red stop sign. I have given a material to all of my entities, so there is no "entities needing a material" message on my model. All the domains seem to have a material assigned. There is a stop sign next to each of my materials so I do not know what is wrong.
Thanks!
1 Reply Last Post 29 janv. 2015, 06:14 UTC−5
Posted: 10 years ago 29 janv. 2015, 06:14 UTC−5
Hi Marina,
You might not have filled some of the property parameters/values in each of the materials you have selected. Since you have no "entities needing a material" message, this might be the only problem.
Anuraag
Hi Marina, You might not have filled some of the property parameters/values in each of the materials you have selected. Since you have no "entities needing a material" message, this might be the only problem. Regards, Anuraag
