model.param.set
Are there someone would like to give me some help about 'model.para.set'?
I have three variables in comsol model, which are p_1, p_2, p_3.
So in my matlab function, I worte
model.para.set ('p_1',x(:,1));
model.para.set ('p_2',x(:,2));
model.para.set ('p_1',x(:,3));
Is there some way to write them somehow in one sentence, like
model.param.set(p(j),x(k,j));
this is totally wrong, but I want to find a way to call 'model.param.set' only once and deal with a matrix rather than several times deal with an element each time.
Thanks for the help in advance.
Best regards
Yanrui
1 Reply Last Post 30 déc. 2014, 19:32 UTC−5
Posted: 1 decade ago 30 déc. 2014, 19:32 UTC−5
more explanation of the problem
I use genetic algorithm to optimize a design which is simulated in comsol
I ran profile in matlab and since I can't reduce the time costed by comsol built in function, I am trying to reduce the time that comsol functions being called. Let the functions do more work each time by vectorization.
now my code is like
parfor k=1:size(x,1);
model.para.set ('p_1',x(k,1));
model.para.set ('p_2',x(k,2));
model.para.set ('p_1',x(k,3));
end
This code will call 'model.para.set' amount of time during running.
if it is able to write like
model.para.set ({'p_1' 'p_2' 'p_3'},{x(k,1) x(k,2) x(k,3)});
end
which is wrong but could reduce the calling time to almost 1/3.
Further more, the code is somehow like
j=1:3; %three variables need to optimized
k=1:size(x,1);
model.para.set (p(k,j),x(k,j));
which apparently wrong but may reduce the calling time to very few times. besides I may even could use some matlab function like 'arrayfun' later on.
I check use manual and found assign 'pname' could change parameter set to variable in comsol. However I think it is only possible for some special case, such as parameter swept or some comsol built in optimization.
And even 'pname' is not the way I want.
Any ideas about this problem?
Thanks.
more explanation of the problem I use genetic algorithm to optimize a design which is simulated in comsol I ran profile in matlab and since I can't reduce the time costed by comsol built in function, I am trying to reduce the time that comsol functions being called. Let the functions do more work each time by vectorization. now my code is like parfor k=1:size(x,1); model.para.set ('p_1',x(k,1)); model.para.set ('p_2',x(k,2)); model.para.set ('p_1',x(k,3)); ... end This code will call 'model.para.set' amount of time during running. if it is able to write like parfor k=1:size(x,1); model.para.set ({'p_1' 'p_2' 'p_3'},{x(k,1) x(k,2) x(k,3)}); ... end which is wrong but could reduce the calling time to almost 1/3. Further more, the code is somehow like j=1:3; %three variables need to optimized k=1:size(x,1); model.para.set (p(k,j),x(k,j)); which apparently wrong but may reduce the calling time to very few times. besides I may even could use some matlab function like 'arrayfun' later on. I check use manual and found assign 'pname' could change parameter set to variable in comsol. However I think it is only possible for some special case, such as parameter swept or some comsol built in optimization. And even 'pname' is not the way I want. Any ideas about this problem? Thanks.
