Internal error in geometry decomposition
I am getting this error whenever I click on the subdomain settings in the Physics tab. I am unable to understand why this error is coming? It says error 2100 Internal error in geometry decompositon.
Salil.
1 Reply Last Post 14 mai 2010, 02:04 UTC−4
Posted: 1 decade ago 14 mai 2010, 02:04 UTC−4
This means really that your geoemtry is such that COMSOL cannot finish to analyse it, it could come from many sources, such as lines not touching each other, unclosed domains (a few microns gap between some lines is enough, and is difficult to identify. Perhaps you should try to, in Draw mode, select all geoemtry and hit he coerce to solid or composite object.
Basically it means recheck your geoemtry in detail, there are a few other discussion about this, use the search of the forum (the [Go] button above) on the error message
Hi This means really that your geoemtry is such that COMSOL cannot finish to analyse it, it could come from many sources, such as lines not touching each other, unclosed domains (a few microns gap between some lines is enough, and is difficult to identify. Perhaps you should try to, in Draw mode, select all geoemtry and hit he coerce to solid or composite object. Basically it means recheck your geoemtry in detail, there are a few other discussion about this, use the search of the forum (the [Go] button above) on the error message Good luck Ivar
