3 mai 2010, 05:06 UTC−4
Sorry,
the file didn't get attached.
Here it is!
Sorry,
Here it is!
4 mai 2010, 12:01 UTC−4
Last try to upload the file
4 mai 2010, 15:34 UTC−4
if you have trouble uploading it could be because the file is too big, try to zip it first, or to do a "reset model" to leave us mother redo the analysis. If you do a reset model, be sure COMSOL is not saving the geometry as a separate file, in which case you must submit BOTH for us to rebuild it.
So without a model, my only guess is that your case is sufficient non-linear that the "large deformation" is better tracking reality, and that your analytical calculations are based on linear theory. But this is just a guess, you could also be unlucky with some values entered, and the results are somewhat wrong.
Hope this helps on the way
Have fun Comsoling
Have fun Comsoling
16 mai 2010, 16:38 UTC−4
Looks like it's going to work this time! Firewall issue.
Yes the analytical calculation is based on linear theory of pull-in voltage for thin membranes. The main assumption being that the deformation is very small compared with the length of the membrane....
Anyway, if someone wants to have a look at it, I'm still interested in any comments or advice (I'm failrly new to Comsol and to mechanics!)
Thank you
Elodie
Thank you
Elodie
