Accurate inflow/outflow calculation
Posted 16 nov. 2014, 11:40 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD), Results & Visualization Version 4.4 2 Replies
Hi, I'm using the Free&Porous workflow, but the question is also applicable to Navier-Stokes.
I have an inlet and use NormalVelocity boundary condition which, it seems sets up a Lagrange multiplier to enforce u = u_0. No problem.
But when I do an integral over the inlet surface to check that total fluid-in matches the desired actual fluid in, then I have a big error (>20%). Yes, I could mesh more finely....
But I thought I remember a "trick" for accurate calculations of flow across a surface. Isn't this equal to a Lagrange multiplier or something? Maybe I am misremembering.
Does this ring a bell with anyone??
Thanks, John
Thanks, John
2 Replies Last Post 20 nov. 2014, 12:03 UTC−5
