why velocity of fluid is constant over the entire field?
hi everybody,
i have a simple heat exchanger. please suppose a pipe which in the middle of it there is a heat source. the fluid pass around it. i use U constant at z axis velocity and outflow boundary. i expect that the velocity at various point in the fluid is different but the the velocity is U at all points!
can anybody help me.
thank you,
ras,
regards,
2 Replies Last Post 23 sept. 2014, 14:49 UTC−4
Mikael Noerregaard Nielsen
Posted: 1 decade ago 23 sept. 2014, 08:06 UTC−4
Hi Sharif
I don't quite understand what you mean, could you please attach your model?
Best Regards
Hi Sharif I don't quite understand what you mean, could you please attach your model? Best Regards
Posted: 1 decade ago 23 sept. 2014, 14:49 UTC−4
Dear Mikael Noerregaard Nielsen,
Thank you for the reply.
For a time I don't work with COMSOL.
Sharif
Dear Mikael Noerregaard Nielsen, Thank you for the reply. For a time I don't work with COMSOL. Regards, Sharif
